14-09-2017, 04:27 PM
Also try measuring between mains earth and your rods. Check on AC volts initially, I get 45mv and 0.5 ohms. If I connect a long wire directly to a set and a mains earth noise is awful, use the earth rod and it reduces considerably, connect both and its nearly as bad as the mains earth on its own.
