11-05-2012, 07:20 PM
Hi,
Many thanks Tony; I'm pleased you liked the video. As you know Tony in America they go over the top on workshop kit and to rub it in it is much cheaper in America than over here; it was a few years ago when I used to check so I assume this to be still the same. Bron and I used to like watching “This old house” and “ New Yankee workshop” both American long running TV series. Norm Abram wasn't just a master craftsman but an excellent teacher; I picked up lots of advice and trips from watching his shows.
http://www.thisoldhouse.com/toh/tv/history
http://www.newyankee.com/index.php?id=48
Thank you for your kind comments David they are much appreciated and I hope I can follow through. I still find many of my projects to be daunting because they all tend to be different forcing me to think things through rather than simply repeat previous processes. Anyone could do what I do as it only comes down to practice over many years and making most of the mistakes that can be made. I enjoy such work and see it more of a challenge than a chore. It's not like me but I've been very slow to get stuck into this desk project and at first lacked enthusiasm mostly due to the lousy weather which continues to upset me.
Your 6” surface planer is actually a good size David for a small home workshop and if this is coupled up to a decent saw bench by using both together rough sawn timber can be dimensioned reasonably quickly using the technique I outlined earlier. For serious work hand planing just doesn't cut it; hand planing is hard work and requires a lot of skill if long surfaces are to brought to right angles to each other; getting one right angle is difficult enough to give a face side and face edge but to plane a true square or rectangle over say eight feet in length would I fear prevent most people from making anything in timber; softwood is easier but timbers like Sapele with interlocking grain that runs in opposite directions every inch or so across a board is enough to cause nightmares. Such timber ends up with strips of alternating dead smooth and ripped up. I once bought Maple flooring from an old local mill with the intention of making some cheap furniture when Bron and I first married; I couldn't even cut this using a hand saw and the hand plane simply skated across the surface; I gave it away for firewood.
Light cuts is the way to go as you rightly say David with the lighter machines. A good workman respects his tools/machines and any power tool that is labouring is being abused. Cutters must be sharp and everything kept in good condition and in adjustment; an oil can is a must but oil should never be allowed to contaminate metal to metal clamping faces; the large fence assembly on the Startrite moulder springs to mind here; if this fence was allowed to move whilst timber was being fed into the high speed cuter head a serious accident could occur. For many years I never liked routers but recently I've made friends with my very cheap (£15 new) B&D 1/4” router and I'm finding it of immense use whilst working on this desk. I used to have plenty of space until I filled it with my toys.
Yesterday I felt hot in the afternoon but this morning I felt perished and just didn't want to venture into the garage; the wind was bitterly cold and cut through me. I did however visit “Boards” and bought four lengths of softwood 1” x 4” to use initially as saw and router guides and later as the desk takes shape as drawer sides. From Boards I popped into my favourite store “Screwfix” and bought two 500ml cans of Evo Stik impact adhesive and also 1ltr of Resin W Weatherproof adhesive these setting me back £27.97. Then it began to rain. After dinner I stopped sulking and put my best clothes on and went into the garage as it had stopped raining and had warmed up a bit; with my coat on I soon settled down to some work. I spent a couple of happy hours cutting the MDF and Formica to length; I had already cut them to width.
Fed up with working on the garage floor I wheeled out the Startrite combination machine and used the remaining piece of MDF to make a nice big table. This was sheer luxury; being able to work at waist height in comfort. I used the newly bought softwood as clamps to sandwich both the previously ripped MDF and Formica; cutting the MDF to finished length for the four desk sides using the big Skil-saw and the Formica extra long for later trimming with the router. Care will be needed to remove all the dust from these before glue up as I don't want to see any little mountains in the Formica after it is glued into position.
Cutting MDF and Formica to length.
Cleaning the car then having a bath finished the afternoon off. Tomorrow I think I'll be attempting to attach the Formica to the MDF panels which reminds me; I intended to cut a lot of strips of 6mm MDF to use during glue up but forgot to do this. Once the panels are completed then perhaps I can relax a bit and make a start on the oak framework.
Kind regards, Col.
MDF and Formica now ready for glue up.
Kind regards, Col.
