10-11-2011, 10:37 AM
(09-11-2011, 11:00 PM)Steve_P Wrote: Well, today I came home from B+Q with..
Gloves, Eye glasses, A mask, some groundsheets, fine wire wool, medium sander, brushes, wood dye of the nearest colour, furniture stripper, tape.
What else do you recommend and how do I start?
Cheers,
Steve P.
My advice would be to avoid using sandpaper - the veneer is very thin (modern veneers are just 0.6mm). When you apply the stripper, after a few minutes the varnish (probably cellulose lacquer actually) will start to bubble up. The best tool to use to remove that is a cabinet scraper - certainly not a paint scraper, but you could use a plane iron with a burr on it, or even a wide chisel, but go gently, and never work across ther grain - always with it. Steel wool allone might suffice.
B&Q won't sell any sandpaper fine enough to use on venner - they probably call it 'coarse, medium and fine', but probably dont say the grit number on the back. Personally, about the coarsest paper I'd use would be 600 grit, and then only sparingly. For that, you probably need wet and dry paper, but don't use it wet.
As to wire wool, make sure it's 0000 or 00000 grade - no coarser than that. It you use any grit - for example, 120, you then need to go progressivly through the finer grits to remove the score marks of the lower grits - you can't just go from say 120 to 600 in one jump - you'd have to use 180, 240, 320, 400 and so on. That's ok on solid wood - for example a bowl being turned on a lathe, or a solid wood table top, but would wreck veneer and be through to the base wood in no time at all. Be especially careful on the bends as it's very easy to cut through the veneer.
In short, the more gentle you are, the better will be the finish on which to apply shellac or whatever. Think 'butterfly's wing'! You can't apply a good finish on a poor base, any more than you can put lipstick on a pig to make it look more attractive:D
As hobbyists, we may not have the skills that professionals have, but we do have something that they don't have - time on our hands. The more time we take, the more care we take, the more professional the end result.
Colin has never had any training and never taken a penny from anyone, but the end results he attains are in every sense of the word 'professional'. The one thing an apprenticeship in any trade gives us is 'pride in the job' - doing things up to a standard - not down to a price. It doesn't take much longer to do the job properly than to bodge it. Indeed, it sometimes takes less time, for a more pleasing end result.
Best of luck with it Steve - do keep us informed of progress!
BVWS Member.
G-QRP Club Member 1339.
BVWS Member.
