07-11-2017, 05:49 PM
Excellent progress, Trevor
Those 5 pin connectors are notorious for playing up. Contact cleaner and a squeeze often does the trick, but many times the soldering needs to be reflowed, even if it looks OK. It's a shame they didn't use a different connector with more pins, as then they could have used two earths - one for signal and one for power.
I'm not sure I have any spare AM IFTs for that vintage of set - I haven't scrapped any as yet. To widen the net a little, the RP35 Herald and RP36 Helmsman uses the same IF PCB. What I don't know off the top of my head is if you'd need to find a germanium set - the manuals I have here don't list part numbers for the IFTs in the supplements that cover the silicon versions of the IF PCB.
