19-11-2018, 03:26 PM
(This post was last modified: 19-11-2018, 03:27 PM by ppppenguin.)
P series valves were used extensively in TVs. All the heaters were wired in series so you add up all the voltages. Then use a big resistor to drop the difference between that and the mains. Same idea as using U series valves in radios.
A number of valves, such as EF80, are 6.3V 300mA heaters. So you can use them in series chains at 300mA or in parallel at 6.3V. The heater is just a resistance, albeit one that varies a bit with temperature. So it doesn't matter whether you think of it as 300mA heater or a 15V (or whatever) heater. If you have a number of 300mA 15V heater valves you can run them in parallel from a 15V supply.
For the valve audio folk, take a bunch of PL519. 300mA, 40V heaters. Bung 6 in series and connect direct to mains. No problem apart perhaps from safety. Or use a 40V 2.4A transformer. Makes no real difference to the valves.
You can do anything with an EF80 (or EF91). People have built radios using only these valves. You can just about do a small TV though line scan is a bit tough.
The EF80 is a tough critter.
